Re: 2 Cycle Fuel Injection
On certain Direct Injection engines, the fuel injectors are "flow-compensated".<br /><br />For example, in order for a DI engine to run properly at all rpm, the injector must deliver a nominal amount of fuel over the rpm range. Due to manufacturing variances or assembly tolerances, one injector may flow lean, while another may flow rich. <br /><br />In order to compensate for this (and not throw bunches of injectors in the scrap heap), the manufacture will use software to control the pulse-width ("on" time of the injector) to make it flow correctly.<br /><br />So it you put a lean flowing injector in a cylinder that's compensated for a rich flowing injector, it will deliver even less fuel and destroy the cylinder (leaner = hotter).<br /><br />Make sense?<br /><br />-John
