I have a 1986 110hp vro mod.#e11omlcdc ; ser.#r1308421.
Ran good in the yard the night before i took her out. I start it up at the dock and no wake cruise passed the no wake zone and go to accelerate and it grumbles and barley moves at full throttle. I stumbled back to dock and took out the tool kit. 2 cylinders on the same side were not firing. The heads on that side were cold to the touch and the plugs were fouled. The dead cylinder plugs' center pin was shaped at an angle instead of being flat. Almost as if I filed the point with a file at about 30 degrees. I installed a set of clean but used plugs for just such an emergency but there was no difference. I started it up and in nuetral it would get to about 2000 rpm wide open. I cleaned the coil ground straps and checked the connections going to that side of the engine for the most part. Still no go. I don't think it's the coils cause what are the odds of 2 coils failing at the same time? Can any one help me fix the problem? 2 weeks before it sat in the yard she ran great for 2 years.
