I posted earlier regarding continual carb clogging problems, I believe due to the motor ('98 4 stroke 25 hp) sitting too long w/o running and also in the sun. As you may know, any tiny bit of crud in these carbs and they're clogged. So...is it OK to put a filter both before the fuel pump and one after? My reasoning is that even if i drain the carb, there's still going to be fuel in the pump to get nasty, so filtering at two distant points along the fuel line might help considering how delicate the system is toward crud in the gas.
And if I do this or not, is there a recommendation for the best possible gas filter, or is any lawnmower type or wally world type OK? THANKS!
