Keith Jones
- Joined
- Oct 15, 2008
- 6
Help! my last inquiry was re suitable compression on 1974 2 h.p evinrude..did a test and it is 100 lbs. I have spark but not sure strength. Will not fire even when fuel is put into cylinder??? I am going to check spark strength (not quite sure how to do this).Please advise. If not good I will pull flywheel and check coil etc. I will have to borrow a puller. Can you also give the size of bolt (diameter, thread, length, hardness) I will need for this task.
Thank you so much
Keith
Thank you so much
Keith
