The coil and condenser are brand new. The spark looks good. I have spark testers but not adjustable. I have a Briggs & Stratton testor with a visible window where you can see the spark jump. The flywheel is off right now so I can't say the exact length of the spark. What I can't understand is why it runs great (high speed and idle) with the prop off but the extra load of the prop seems to be enough to put the motor over the edge and not run. The points have not been replaced but I don't see them as the problem since it does run great when not under load (points set). As for the needle settings they were both adjusted (with the prop off) to the best running; both idle and high speed. The numbers on the dials mean nothing- just a point of reference. Another mystery motor. I've found some run great and others seem to have a 'ghost.' This is one of them. Hope somebody can solve this as it's really a simple motor. Just a thought; could the ignition wire be the problem? I've replaced everything else.
Check, clean, and reset the points then. Clean means
CLEAN!
Is the coil correctly positioned on the armature plate
SEE
http://forums.iboats.com/forum/engin...s-on-old-omc-s
Check the spark . Inspect the HT plug wire. If you do it in the dark you should see any insulation failure.
Is the plug correctly gapped to 0.030"
Make sure you have tightened the packing retaining nuts on the carb needles so that air cannot be drawn in, (#16)
is the carb float correctly fitted and is the height correctly set. Is the little spring clip between the needle and the float arm fitted (#20)
Check that at full throttle the throttle pate in the carb is fully open.
Check that you have good fuel flow to the carb
Gently seat the carb needles and then adjust them to the basic settings.
Fit the prop and finely adjust the slow running needle in the test tank
Then fit the engine to the boat and take it out on the water to finely adjust the high speed needle
SEE
http://forums.iboats.com/forum/engin...-by-joe-reeves
BTW fuel mix ix 50:1 even if the decals or the owners manual says different!
