My 1982 (not '81 as typed in previous post) Johnson 2HP starts up pretty easy but when I gave it gas it would die. The only place it would run is when the lever is pointing at "Start". I posted this question on June 21 and got a response about the carbs, which was my thought too. Since then I have taken the carbs apart, cleaned them and it still does the same thing. The first time I tried to use it this year was on a hot day on a farm pond in a jon boat. Now I have it in my garage in a trash can full of water. Now I think my problem might be electrical. Is that possible? and if so where should I start? Also, I bought a clymers manual. It primarily addresess starting and fuel problems. I have found out it also dies when you try to run it slow.
