HopinImFloatin
- Joined
- Sep 21, 2010
- 136
i know temp. effects the expansion of foam, also mixing mechanically is better, but does high humidity effect the expansion also?
yes, right from the can, first part A, let it settle a bit, then part B to the 1:1 ratio marks and mix
thanks for the advice guys, i was doing very small pours experimenting(like 8 ounces total). I think I will use the 3 cup deal to do the rest, makes sense. I was hoping to get it all done with just the 2 one quart cans but it doesnt look like thats going to happen![]()
I've done the foam a bunch....and you need three containers. Mark one Part A and one part B. Pour equal amounts of each into the cups A & B the pour them both into C. You'll need a new C cup each time but just use A and B over and over again. I wouldn't recommend pouring right from the containers....too big risk of improper ratio's, plus you loose some mixing time with the drill.
CW
