SKIBUM1M
- Joined
- Jul 17, 2009
- 604
I have a 1966 60 horse johnson and am having major problems with my props. this is a pin drive prop and the first had the cap and cotter pin. I was coming into the dock to fast so used reverse and it didnt seem to work. i loaded the boat and noticed i had no prop. looked for it but no luck so i bought a used one I didnt have the pin and cap so i used a shear bolt. Everthing seemed fine with it but when i had the engine run well for a day the rubber broke free. Wanting to get out on the water while i wait for a new one to get here from ebay i drilled a hole thru the prop and hub. I installed a bilt directtly thru the prop body, hub, and the shaft. Today the engine seemed to run the best it ever has but when i tried to really take off nothing happend. a second prop at the bottom of lake champlain. I have one comming next week that is new old stock and i dont want to lose a third. Any ideas on why i cant keep a prop and how to keep the new one. My idea is to install a second bolt thru the shaft hole for the cotter pin so if i do lose the shear bolt at least this second bolt may keep it on the shaft.
