4runneradam
- Joined
- May 7, 2007
- 203
I have a 1985 Bayliner Capri 1600 that a large majority of the floor and the middle section of the transom is rotted. Stringers are OK. The rotted sections of floor have been cut back until good wood was spotted. My plan is to lay in a new floor in sections, and add a stringer brace where the ski locker was. Transom repair will be done by removing the middle section of wood and adding new wood, possibly sandwiching a sheet of metal for extra rigidity.
For the wood, I was planning on using some plywood from the local home improvement store, and using some resin to coat both top and bottom. Question, do I NEED to lay fiberglass down too? This is a cheap, small, starter boat, but I do want it to be safe, if it lasts a few years I'll be happy. I need this to be cheap, funds are EXTREMELY tight.
I planned on getting this completed during the winter to have it ready for this coming season. Right now its in my garage, which is attached to the house. I have heaters in the garage that make it nice and toasty, but they only get used as needed.
I'm concerned about 2 things. Number one, the smell getting in the house, and the temperature it needs to cure. I've never worked with fiberglass before, but I am going to read everything I can in order to learn. I understand it has a very strong smell, and can be dangerouse to inhale. I have the proper respirator and eye protection. What I was planning on doing was to go outside and apply the fiberglass, and then bring it the garage to cure. It wil be anywhere from 40 to 0 degrees outside, but I can keep it at 70 degrees or so in the garage. How bad is the smell during curing? I'm sure I cant keep it outside to cure, correct?
And my next question. The boat was outside and the cover ripped, so now the vinyl seats are dirty with what looks like mildew or mold. Its black. It doesnt wipe off easily. What would be the best cleaner to use?
Thanks! Hopefully I can work out a plan to get this done. I'll start a thread if I do.
