2 ? s ON A BOAT THAT HAS SAT FOR 3 YEARS
boatman1959
Hello, I have 1977 crusier that I am getting back into the water. First ? is I put a new coil in and I am still not getting spark out of it. with a test light I can see that I have power going to it but with the key on only sometimes can I cet it to light comming out of it . It has a resistor block but I don't know how to check it or anything else to get spark, It is a chevy 305 w/ points.<br /> my 2nd ? is how can I get the lower unit down? It is a volvo 280 outdrive and there are no celenoids that I can find, just a 4 prong plug and the switch is not working. Thanks for any help. Boatman1959
Dunaruna
Re: 2 ? s ON A BOAT THAT HAS SAT FOR 3 YEARS
Boatman, you will need to do some basic checks starting with points & condenser (always the first port of call when you have no spark)If you are not sure how to check then a local mechanic may be in order (dosn't have to be a marine mech)<br />The 280 had a electric/mechanical lifting system (not hydraulic) it sounds like someone has disconected it (why?). Remove the elec. motor (looks like a small starter motor) inside the housing is a slotted rod, turn the rod with a screwdriver, it will take a while but the leg will drop.
