2 stroke additive
phatmanmike
is there anything to add to 2 stroke fuel to help lengthen the life of a motor, i may sound stupid, but i am just wondering, ive never heard anything like this... i already do regular decarbs and run synthetic 100%... is this the best i can do to minimize wear n tear?
jim dozier
Re: 2 stroke additive
You will no doubt be offered a great number of opinions on somebodies' personal favoite snake oil. So I will offer my opinion. 2-strokes rarely die from old age, they are felled by starvation, arteriosclerosis, hyperthermia, and oxidation (lack of oil, clogged fuel system, overheating, and corrosion). All of these can be prevented, not by snake oil, but by routine maintenance and boat hygene. Use the boat often, oil it, keep the fuel system clean, don't let it overheat, and flush it. <br /><br />Rather than purchase somebodies' version of snake oil why don't you just save time and effort and send me $3 US every time you get the urge, I guarantee the same results and I will be happier (richer). :D
LubeDude
Jimd is right, you are doing what you can, just make sure you dont get a lean condition, and you should be fine.<br /><br />If you want to Email me I might have something for you, but there is no way Im going there on this forum.
RJS
I use fuel stabilizer on every tank full. Keeps the fuel system clean; therefore, I assume this helps. My plugs look great when I fog the engine at the end of the year.
phatmanmike
thanks folks, thats what i was looking for....<br /><br />i decarb through the tank and in the plug holes... also run 100% synthetic motor and lower unit oil. i just wanted to make sure i could keep it running happy, as ive heard that todays gas sucks!! so i wanted to know how to make todays gas " good"......<br /><br />thanks <br /><br />m ikey
tailfin10
Not sure if he is right but the most respected mechanic in my neck of the woods says " a little<br />Yamaha Ring Free a day keeps the doctor away."<br />Anybody have an opinion on this stuff? Have been<br />using it according to directions and on mechanics advise but would value different opinions.
Freezebear
While I had my motor apart for sealing a case leak, I decarbonized my pistons Yamaha's Ring Free. I put some on it that evening and after I got home from work the next evening, the pistons were still wet and gooey. Wiped off almost all of it off with a rag. Then followed up with a little wirebrushing and they looked like new. <br />I use Seafoam in my cars every so often. Add it to the gas and oil. You can tell a diffrence if your injectors were dirty. Also comes in a spraycan called DeepCreep. It is great for throttle bodies.
