Re: 2-STROKE OIL
There is a difference in what oil you use, but it depends on your engine. If it is still under warranty I have always recommended using the oil offered by the engine manufacturer in case there is ever a warranty problem, then the manufacturer cannot blame you for using a different oil. If you have an older carb engine just make sure you are using TC-W3 oil, most brands will do just fine. <br />Some of the new oils, however, are part or fully synthetic oils which are more expensive, but do offer benefits to your engine.<br />You can set up the new Evinrude E-Tec, for example, to run on their XD-100 fully synthetic oil. It is more expensive, but you will get more that twice the life out of a tank of oil. INthe neighborhood of 50+ hours under regular use for one tank. <br />Hope this helps!<br /><br />Merry Christmas
