chuckp
- Joined
- May 21, 2011
- 19
Hello Folks,
I've search the forums and read the top secret files although I have not found my exact issue.
I have a 1971 20 hp Johnson manual start tiller motor model no. 20R71S. I recently purchased this motor and do not know much history. Issue started with too much gas coming out the front of carb and plugs fouling.
I rebuilt the carb with a Johnson kit from BRP replacing the float, float needle, washers, main gasket and carb to head gasket. Cleaned and made sure all passages were clear with compressed air. Also manually cleaned the high speed jet with a piece of copper wire. I set the float per the TS carb post and set the low speed jet per that TS post.
Vented gas tank, connected fuel line in proper direction and pumped up primer bulb and motor started right up. Motor runs ok with a little throttle for about 45 seconds. While trying to adjust low speed jet, motor starts spitting and dies. Plugs look better although I have to set the low speed jet to about 1/2 to 1 turn from gentle seat to get plugs to be dry and golden brown in color.
After this motor will only run for about 5-10 seconds running rough and spitting. I try to advance throttle but this bogs the motor and it dies. After awhile the motor does not want to start and run anymore unless I let it sit for awhile or pull the plugs and cycle engine to dry it out. Best results come when I let it sit for an hour or so and then start the process again.
Spark plugs are brand new Champion J4J replacements (J4C) - it has blue arc with plugs about 1/4 away from block bolt and the primer bulb is firm but not tight. Fuel no longer runs out front of carb and drips on inner cowl but is slightly evident at front of carb.
Motor pumps water while it's running - it seems like I'm close to getting this motor running properly but I must not have something adjusted correctly or maybe it's sucking in air somewhere?
Chuck
Chuck
