craigrs8271
- Joined
- Nov 23, 2007
- 11
I need Help!!!!!!!
I bought an older boat for crabbing in the bay. I figured it was only $450 for the boat with a fish finder & 20 hp Evinrude that ran.
It has a 1988 20 hp Evinrude on it.
When I bought it the motor ran rough..It was sitting for a year,"""SO THEY SAID!!!"""'' I figured the basics it will run good......
I took it home put new plugs, I found the tube in the carb. to be broken. I ended up buying a used carb & boiled it out putting a new carb kit into it.
I fired it up & it still ran rough.
I cleaned out the fuel filter, took apart fuel pump cleaned it up. I have a new gas tank ,new hoses & fittings.
I have done a compression check with results being 125lbs in both cylinders.
Both coils are sparking good !!!
It fires up & idles a little ratty & when I put the throttle to it thats the end of it, dies out ..
Any IDEAS????
thank you
craig
Any IDEAS????
thank you
craig
