knight hunter
- Joined
- May 12, 2007
- 29
Today I put my 1976 Johnson 20 hp in a barrel of water to check it out B4 mounting it on my boat. it started good ( 2 pulls) It would run good on fast in neutral, but when I slowed it down to shift or slow, it would cough or stall. It almost seemed like it was getting a shot of air in the fuel line somewhere. I checked all the connections from the fuel tank to the carb, all were tight. Then I bought a new fuel line(from tank to motor). still have the same problem. Is it possible that I need a new tank( this one is original) or should I be looking towards the carb? fuel filter? Any idea's. I also mixed up fresh gas and added some Sea Foam B4 I started it. Thanks in advance for any replies. I also put in new plugs. my fuel tank is an OMC metal tank. When I close the tank and pump up the primer bulb, the tank is air tight, when i open the tank cap, there is a release of air pressure. By reading other posts, I get the impression that there is a valve in the cap. If that's the case, why is my tank air-tight?
