John Drew98
- Joined
- Feb 13, 2020
- 72
Replaced waterpump and started the motor up and I put the shifting leaver in netural position but the prop still turns. The linkage screws both tighened and seated all the way. The video shows forward and the prop turns, next is netural and it turns, then reverse and it turns. I did fill the lower unit with recommended oil, I now hear the gears turning which perhapes is okay. The main issue is no netural for the prop not to turn even when the shifiting leaver is in netural position. https://www.youtube.com/watch?v=qb3uIwYK7Zk The pictures show the groove on the shifting rod is just below the connecting bracket and the rod does not go into the left hand side.
