20 hp johnson
bernard410
will not crank over with plugs in take them out and it will crank over very fast what is causing this
jbjennings
Re: 20 hp johnson
hope you got it fixed. The above post looks exactly right to me!:redface:
JBJ
F_R
Re: 20 hp johnson
thanks guys willcheck the cables out
You checked the battery, right? Could be discharged or have a dead cell. If it isn't the cables or a bad battery, the last item is a bad starter. That starter should whiz that little motor.
