Got 1980 20 hp merc *561----- running after switch box/charging coil replace and carb rebuild and to the lake the last two days,
ProbleM: Running at 1/4 throttle it misses pretty bad and at 1/2 throttle it will run fine then stop as if I pulled the kill switch, but then restarts on first pull.
I did not replace the fuel pump diaphram as it looked good and did not have one but that may be my problem.
Any thoughts.
Where can I get a "complete full pump and carb rebuid kit??
Thanks
John12
Any thoughts.
Thanks
John12
