20 hp merc,idle and take off problems
jacksok1
idles rough and when you start to take off it boggs down and dies,acts like it's running out of gas.If you ever get took off runs like a charm,but when you let it idle for a couple of minutes and try to take off same thing.
tashasdaddy
Re: 20 hp merc,idle and take off problems
clean and rebuild the carbs.
stompie
I had a similar problem. If it idles rough and dies under load....check your compression. My motor compression was down on two cylinders and eventually required a rebuild. Do carbs first as this may help but check compression while you are at it. Mine used to start and idle no problem... just a bit rough. As soon as it was in gear and started accelerating it cut out. Once you managed to get it going it ran like a scalded cat.
Good luck
Jugfisher
I agree with Stompie. Check compression. I spent alot of money thinking that it was a fuel or fire problem on my 70 hp merc but turns ou that the #1 cylinder was in pieces. If you ever have a problem always good to check compression first. A compression tester can be inexpensive but you get what you pay for. If you can I would atleast get a mid-grade compression tester wich would be about 30-50 dollars.
Windykid
How about the basics, Try pumping your fuel bulb first while takeing off. Check the color of your spark plugs. Check compression. Rebuild carbs. Decarb.
