How do I tell which one I have? What exactly is being measured?
D duhn Petty Officer 3rd Class Joined May 17, 2008 Messages 76 Oct 23, 2009 #1 How do I tell which one I have? What exactly is being measured?
F FAC Petty Officer 3rd Class Joined Jul 30, 2009 Messages 79 Oct 23, 2009 #2 Re: 20" or 25" shaft to measure an outboards lower unit length measure from where the mounting bracket sits on the transom to the av plate and to measure the boat you measure from the top of the transom to the keel
D duhn Petty Officer 3rd Class Joined May 17, 2008 Messages 76 Oct 23, 2009 #3 Re: 20" or 25" shaft FAC said: to measure an outboards lower unit length measure from where the mounting bracket sits on the transom to the av plate and to measure the boat you measure from the top of the transom to the keel Click to expand... What's the AV plate?
F FAC Petty Officer 3rd Class Joined Jul 30, 2009 Messages 79 Oct 24, 2009 #4 Re: 20" or 25" shaft the anti vetilation or av plate is outlined in blue and you should measure from green arrow to green arrow
JB Honorary Moderator Emeritus Joined Mar 25, 2001 Messages 45,907 Oct 24, 2009 #5 Re: 20" or 25" shaft Most boat transoms are not vertical. When you measure the transom, measure the vertical distance from top of transom to level with the keel.
D duhn Petty Officer 3rd Class Joined May 17, 2008 Messages 76 Oct 24, 2009 #6 Re: 20" or 25" shaft Thanks for the illustration.
