20 PSI Oil Pressure at idle normal ??
mattb1974
Is 20 PSI Oil pressure normal at idle on a 1998 VP 5.0 GI?
Engine completely warmed up on water 50 PSI when rpms are up. 20 psi when at idle. 6 hours of running, full throttle, part throttle cruise and idle along. Engine ran great !!
The hottest the engine got was 150 degrees.
Air temp today was 85-90 F all day
Cold start the Oil Pressure is 40 psi idling.
Oil was new at winterization last fall. 30 weight dino. Still looks new.
Maybe I am just a little paranoid?
zbnutcase
Re: 20 PSI Oil Pressure at idle normal ??
Your paranoid. As the small block Chev only requires 10psi per 1000 rpms to live a healthy life, your fine!
mattb1974
Thanks 'nutcase, you set my mind at ease. I am used to seeing my 2004 GMC truck 5.3 liter with 40psi at idle. Guess boats are a little different.
Lrider
My 2 cents
I know nothing about this stuff :D
Ayuh,.. Sounds completely Normal to me...
cr2k
The SBC in your boat is a completely different animal from your 5.3
Just about any oil pressure at idle is OK for a SBC, just don't get up over 70 on the high side or they tend to spin bearings.
Marine engines use a high volume pump and not high pressure.
