20' trihull, began floor redo at bow, now I'm at the engine bay, have builder's
Bodhi
Working on a trihull deck boat. Like most here, floor was bad, motor mounts were bad, so I ripped it all out. Doesn't have wood stringers. I've laid in floor all the way to where the engine sits (from bow-stern), but I haven't done anything yet to the left-right of the engine. The motor (Old V6 OMC, so no alignment issues) was falling through the floor because the wood under the glass was mush. I've been eyeballing the area the whole time I've been doing the floor wondering how to redo it. I didn't see much here about refabbing this particular area. What was originally there, best I can tell, was a stack of 2x, but there wasn't enough left to see if it was all the same width. The FG stringers angle away from the hull of the boat in this area, and the hull also slopes down towards the keel. So if I just go with a square-shaped "box" of 2x4's, I'll end up with a gap under one side, and a gap between it and the stringer.<br /><br />I'm trying to get some pics up, but I use my vid cam as a dig, so they're crappy and prolly won't help...
Realgun
Re: 20' trihull, began floor redo at bow, now I'm at the engine bay, have builde
Most of the boats with an I/O drives sit on 2x.<br />They are glssed to the floor and are open in the rear and front. I would suggest a call to the Factory or dealer to see what they used did.<br />Hope this helps.
steve n carol
bodhi, check out serch305 and JasonJ. they are on this topic. and are currently working with the same conditions..sl
