I have a 1986 200 XP Evinrude that has 50 hrs. on it sense it has been rebuilt.It ran good for the first 35 hrs.This is what it is doing,when you first start it up at the lake and take off it runs great. I can run it as long as I want and it won't miss a lick. After I stop, for at least 10 min.The engine will start but when I give it the trottle it dies out. If I rev the motor up for 5-10 seconds and jamb it into gear as the r.p.m.,s go down it will go.I was told that Evinrude had some design problems with this engine.There were several things that the factory came out with to correct this problem, I have been told that all of those things were done to my engine except for one. My engine has large port carbs on it,I'm currently having the carbs change out to small port. I have already replaced both power packs,all the thermostats, fuel pump,complete tune up, I have checked the timing and advance while the boat was being operated.The oil pump has been removed and I mix all of gas.I put O.M.C. 2+4 additive during storage.I'm running out of solutions and money,HELP!
