200 hp mercury looses rpms when let go of shifter
boating3104
I just bought a boat with a 1981 200 hp mercury outboard it runs strong but when I let go of the shifter it slows down as long as I hold it its fine is there a way to adjust it
boating3104
loose throttle when let go of shiffter
Grub54891
Depends on the shifter, some have a thumbscrew to adjust friction, some have a set screw for adjusting tension. Normally seen from the outside of the shifter housing. Haw about a pic of the shifter?
dsiekman
Top mount or side mounted shifter? My boat used to do that too. Popped the cover off and tightened the tension screw and it was better.
