2000 Johnson 50hp J50PLSSM won’t start
Kevinsikes03
The motor won’t start rebuilt the carbs have good spark it tried to start a couple of times but will not do anything now has around 120 psi compression on both cylinders will not even try to start with a little starting Fluid just took the flywheel off gonna check and clean everything and check stator could it be the timing maybe any help would be greatly appreciated I’m scratching my head on this one
----There is nothing under the flywheel that will improve starting after a cleaning.------Charge up the battery.--------Take the flywheel off to check the flywheel key perhaps.
Nonyab
From your post it seems you know what you are doing so I won't suggest you check the air in the tires. I have had the same problem recently with a 1992 90HP as well as a 2000 50 hp PL. You know it takes 3 things for an engine to fire off,--- fuel, air, and ignition. You have at least 2 of these being--- ignition and air. I found out on my engines, and you have the same primer system, that the primer was not priming the engine as it was suppose to. (The 90 would spin all day without firing). After I ensured my fuel bulb was tight, I kept hitting the primer button, probably 30 times and with the start lever up, it started firing. I kept motoring and hitting the primer button and it lit off.
I have never been a fan of OMC's start system but have 2 of them in my yard. I always let my engines run themselves out of gas when I load them after fishing and when I have to start it a few days later I really have to give that primer button a workout.
I am sure you already know about my suggestion. Oh yeah, make sure that primer solenoid at the carb is working properly. I know mine work, but I doubt they are giving the initial amount of fuel necessary for the engine to fire of when I hit the starter.
The electric primer is nothing but a simple solenoid valve.----They work very , very well.----Push key in and hold it in WHILE cranking it over.----Will give you near instant starts on a motor in good condition !!
Nonyab-----How many year experience do you have in trouble shooting.------How many motors do you own ?
Nonyab
If it's important, 47 years, have to check my inventory for # of motors. Can't see the relevancy of how your response relates to the initial post. That's why it is extremely rare for me to post on a forum---too much expertise.
Kevinsikes03
Got it running got a spark tester and didn’t have enough spark changed ignition coil and she busted right off
