2000 Mercury 125 outboard tilt switch on the outdrive won't work
Lakedoc
Hello, all!
I haven't been on in awhile, but I thought some folks here might have an answer.
My 2000 Merc 125 Tilt switch on the outdrive won't work, although the one at the throttle stick will work.
I checked all connections and the fuse under the engine cover, but I didn't see anything obvious. Any ideas?
Thanks in advance,
Dan
GA_Boater
I'll say you haven't been here in a while - You just joined today. :confused:
Maybe the switch is bad? Try bypassing the switch with a short jumper wire.
