BrodyDog757
- Joined
- Oct 10, 2019
- 1
I have done just about everything and cannot figure this thing out. Any help would be greatly appreciated.
I have a 2000 Mercury ELPT 90 HP FourStroke (carbs) that I cannot get running correctly. The motor starts right up, however, it idles a little rough but will stay running. The more I advance the throttle, the worse it runs until it eventually bogs down and dies. I have done the following to try to get it running:
-Rebuilt and cleaned the carbs (twice).
-Replaced all fuel lines, filters, primer bulb.
-Cleaned and inspected fuel pumps for leaks.
-Tried running on external tank with fresh ethanol free gas.
-Replaced spark plugs and coils.
-Checked for air leaks in fuel lines
-New battery
The compression is 165, 175, 180, 155 (could this cause my problems?)
I was also thinking maybe it could be a bad Throttle Control Sensor, Check Valve, Dashpot(accelerator pump). Could any of these cause the boat to behave this way?
I will say that I have not properly synced the carbs, however, I figured if this was the issue it would at least run at full throttle?
I would love to have some other, more experienced, opinions on this? This is my first time working on an outboard but I am usually pretty good with motors, this is proving to be a different animal. Any ideas what I can try?
Thanks
-New battery
Thanks
