boatingfun
- Joined
- Jul 16, 2007
- 38
I just purchased a 2001 fourwinns horizon 230.
when I looked at the boat we started the engine, I put it in gear and when I went to put it back in neutral it wouldn't move. the guy I bought it from messed with it and it went back to the neutral position. but it was just the control that moved back not the actual gear/cable.. it was stuck in forward gear. found that out when I started the boat in the water for the first time! HAHA! there is a clip behind controls that hold the outer casing of the shift cable. when I move the control the whole cable moves through it. I wedged a piece of wood between the side of boat and the clipto hold it. it will work fine and then it will get stiff and bind up. I'm gonna replace the cable but I need the clip. can I buy that clip? I cannot seem to find it online or the controls. I cannot even remove the control from the boat. any help appreciated!
