2000 Volvo Penta Sterndrive
curban
At the end of February the lower unit gearcase cracked in a horseshoe shape around the bottom, all oil leaked out. I had it winterized and after discussion with the individual that did the winterization his explanation was as follows. He said after looking at it the bearing race had broke in half probably from an impact of some kind and this caused the outer casing to crack. There was no gear damage however. To my knowledge I've never had an impact. Any thoughts as to how this happened?
Don S
Re: 2000 Volvo Penta Sterndrive
Got a picture of the crack you could post?
curban
Here are a couple of pictures.
  • IMG_0697[1]
  • IMG_0693[1]
180shabah
Correction, here are a caouple of links to some cool red X's 8)
Curban,......
Down in the Tech, Non-boating forum,....
There's a "How To Post Pictures" thread pinned to the top of that forum.....
It'll explain How to see your pictures.....
bigbrownbuku
did you leave the drive tilted up? i have seen a gearbox that filled the exhaust section through the prop freeze and crack.
