2001 evinrude ficht 200 hp won’t idle
Dmac88
I have a 2001 evinrude 200 ficht that won’t idle. I was at the lake and it was running fine and going to my last spot I took my foot off the throttle and it just died. It crank for 2 seconds and then shut off as it’s almost not getting the fuel it needs to crank. I have sent my emm to ficht emm repair and it has returned with no issues. I have checked compression and all 6 cylinders is at 120. I have changed spark plugs gapped ( 0.28) and indexed. Fuel pump comes on and primes. Fuel pressure at Valve is 33 when key is on and 20 psi after fuel pump is done priming and holds that psi. I know it’s not the proper way to check injectors but unbolted one at a time turn key on and injectors spraying fuel. Blue Capacitor is at 11.6 V. One thing I did notice is when I prime the bulb until hard and crank the engine for the 2 seconds it runs the bulb will not be as hard like it loses pressure somewhere. Any ideas would be greatly appreciated as I am new to this site. Also Harris with emm ficht repair said maybe it could be the tps but I did the required test and it never missed a beat and that is a $220 part that I don’t want to replace just for fun. I was thinking maybe lift pump just wanted opinions. I have saw a lot of post with the same issues from years ago but not any that come back on and give the answer to what the problem was. I forgot to add that it will run at about 1/4 throttle but once I let off it dies. I can also adjust the throttle cable all the way so it turns the tps some
and it will crank and rev.Thanks
Faztbullet
Should have a code tripped if TPS...need to hook to software and test. Could be CPS not syncing..
