2001 Bayliner 17.5, (Eng Model OM256972 Alpha 1) ran fine for 2 years. Now having problem with engine but not until I turn off ignition to fish or swin. Boat will not start again. If I wait about 30 minutes, sometimes it will start and run rough for about a minute and die again. Not enough time to make it to the dock. Changed fuel filter, spark plugs, cleaned spark arrestor and still have same problem. Only seems to happen once boat engine is hot. The funny thing is that once I get home and hook up the flush kit, it starts and runs with no problem even at idle. Suspect either a bad ignition system, vapor lock or maybe water in fuel. No water was noticed when I changed fuel filter. Boat was stored with 1/4 tank of gas and a stabilizer for winter. Could this be a coil problem? Any suggestions with this problem would definitely be appreciated. Nearest marine repair shop is 60 miles away so the kids and I hope for a quick fix. Definitely no fun being towed in but thankful for the people who helped me out.
