2001 Nissan 9.9hp 4 stroke
TheTubeman
Hello I have a 2001 Nissan 9.9 4 stroke. I was wondering if it can changed to a 15hp or even an 18? Detailed info would be greatly appreciated. Part #s would be even better. Oh yah it's a 9.9b. if that makes a difference?
km1125
Yes. You can do a carb change to get it to a 15, but you'd need to do a cam and carb change to get to the 18.
TheTubeman
Can I use the carb that I have and rebuild it to make it an 18? Thanks for your reply.
pvanv
No, the 15 hp carb has a larger throat. You need the complete carb. You must change cams to go from 15 hp to the 18. AND, I should mention that you would need a used cam; that cam is NLA new.
Sea Rider
So the 4 strokes 9.9, 15 and 18 HP OB's shares same exact CC powerheads ?
Happy Boating
