Hello everyone I purchased this boat about 2 years ago and the motor has ran like a top until this past weekend. It started with not wanting to crank unless it has almost full throttle. This is a fuel injected motor and never needed more than just pressing the choke to get it started on a cold start. Today I gave it a basic tune up. New Plugs, Impeller, also ran injector cleaner through the motor with a little less than a gallon of gas. While running the cleaner through the system I noticed tons of fuel coming from the prop area. It went through the entire gallon of gas in about 2 minutes. I checked the fuel pressure and it was 35 psi on idle. If I turn the motor off and pump the bulb gas starts leaking from the exhaust,prop area and I have to give it full throttle to get it started. It is almost like something is stuck open and pouring gas into the cylinders. I took the breather off and pumped the bulb and from what I could tell all the throttle bodies looked the same and no injectors were leaking and I could not tell where the gas is coming from. I am leaning towards the lower pressure pump but really not sure what to troubleshoot next. Any help will be greatly appreciated.
