I have a Triton TR-21 and having issues with the motor on the hole shot. Boat will fall flat and sputter. I have taken to multiple dealers and spent hundreds of dollars and still have the same issue. I used to be able to trim the motor up and get it to plane out after about 100 yard stretch but now it won't come out of the hole. Once it gets out of the water it will run fine. It will have an intermittent surge for a split second and run normal again.this will occur off and on at any given time. Things that have been replace or cleaned:
Cleaned VST tank
Replaced high pressure fuel pump
Cleaned fuel tank
Replaced inline fuel filter
Replaced 3 filters
Had injectors serviced
Cleaned out O2 sensor
Any ideas what to check or recheck? This is driving me insane.
Cleaned VST tank
Cleaned fuel tank
Replaced 3 filters
