2002 merc 60ELPTEFI. Not starting.
James R
Good sparks. Lift pump working , no volts at the high pressure pump connector.
should I look for a fuse, a relay or is this the ECM. Dont have a manual for this.
Thanks. Jim.
James R
OK found the relay but can't test it without a schematic for it. Does anyone have a schematic? Still need to know if there is a fuse involved. Have not found one so far.
James R
Perhaps I haven't found the relay. Found what looks like a connector on the end of a harness. Has the wire colors for the pump but a continuity test shows something else connected. I sure need help on this one.
James R
No response necessary. The pump power comes direct from the ECU. No protection from what I gather. If this is the case this is crap from Mercury.
The voltage shows for a short time only when the ignition is turned on. When the motor is cranked over the voltage is there solid.
