jeffrobinson
- Joined
- Oct 29, 2016
- 1
I have a 125 HP Mercury that has not been ran in about 14 months. Put in water yesterday. Problem only when engine is running, problem does not exist until engine is running. Load alarm noise when engine cranks. When engine cranked for the 1st time there was a lot of smoke at the engine but not now. Took awhile to get engine to crank. Approximately 20 attempts to keep it running. Engine would start and run 3-5 seconds and then die. Eventually had to put engine in neutral and put at 1/2 throttle to keep it running. When i did this the engine stayed running but alarm started about 10 seconds after that. Ran engine and boat for another 10 minutes and alarm will not go off. Engine seems to be running fine, water pump looks to be working. Anyone got any ideas what the alarm noise is ?
