2002 Mercury 9.9 4 stroke
Dan102061
Hi All
Just got this running after it sat for 5 years. It's pumping water and even idles. Question is, is water supposed to come out the hole that is circled?
tpenfield
Is that upper exhaust vent? if so, then you would see some water coming out. The engine should have wet exhaust.
Dan102061
Yes, its a small exhaust hole. A high pressure stream of water comes from the side port, but this rear port barely spits water. Trying to determine if this is normal or if something is wrong
