That info is in your owners manual, which you can DL from
http://tohatsu.com/tech_info/manuals.html
Oil changes should be every 50 hours or annually, whichever comes first.
You need NMMA type FC-W, SAE 10w-30. It holds about 1L. DO NOT overfill. The oil level on the dipstick should be at or a little below the full mark; not even a drop above. When refilling, it will take significant time for the oil to read on the stick, so again, don't overfill.
[FONT="]Tohatsu-Nissan 4-stroke models 9.9hp thru 30hp use OEM oil filter part # 3R0-07615-0.[/FONT]
[FONT="]You may also use any filter listed in the cross reference chart below:[/FONT]
| Manufacturer | Part Number |
| AC | PF1237 |
| FRAM | PH6607 |
| LEE | LF2876HP |
| MAZDA | B6Y1-14-302 |
| MOTORCRAFT | FL816 |
| PUROLATOR | L14622 |
| SUBARU | 15208-KA-010 |
| WIX | 51365 |
You will also need an oil filter wrench. Your local auto parts store may or may not carry one that fits.
