2003 Mercruiser 8.1 HO No Crank No Start Fuel Pump Running
mckaras
Wiring diagram in post 14 shows a Yel/Blk and Blk get jumped together
The wires should be at rear of motor
Awesome, that worked like a charm. I'm assuming I would just splice these connections together correct or do they make a female plug that jumps the connection?
They do make a connector (don't know the number) but if it was me I would just cut and solder together. Could probably go to any Dealer and they probably have in stock
mckaras
Yes sir, found it on the engine that needs to be swapped out. Thanks again for all the quick replies and help!
