audiocontr
- Joined
- Nov 8, 2016
- 6
Engine has 200 hours. Worked fine a month ago, start it now and find it running VERY rough. Wont idle. I swapped out the gas and noticed the carbs bowl gaskets were leaking. Replaced all gaskets in the carbs, new plugs, still wont start and run unless i have the accelerator turned up. sputters and pops
Compression shows 175 on 1, 2, and 3. 150 on 4. I'll check the valves after it cools overnight
The engine drops equally when i pull a plug wire across all 4 cyls
Any suggestions of what to look for?
