2004 200 hp 2.5 mercury steady alarm
Si hablara
Hello ! New here! My 2004 200hp efi engine has a steady beep when turning ignition on without starting it. Checked oil pump and is not that! Checked connections, changed battery (if voltage was bad), checked a lot of things and still haven’t found anything! I am frustrated and the technicians are missing in action 😡. Is a steady beep. I am thinking if the alternator is bad and the system recognizes it! Any suggestions? Thanks and happy new year !
gcboat
When you turn the switch on it should activate to let you know it's working. When the motor is running and it sounds off then you have an issue.
