2004 Evinrude HO 150 check engine light comes on
T.bass
2004 Evinrude HO 150 check engine light comes on google says it is a fuel censor , I put a new fuel pump on after about an hour so it came on again, turn it off start motor back it runs fine
Crosbyman
do you have EV diagnostics to show fault codes ?
post engine mdl number !
no sense in changing parts if you do not know the cause. FICHT or ETECs have multiple reasons to activate SYST CHECK with or without putting the engine is SLOW/SAFE mode
for ETECs only.....you can also consult with the ETEC OWNERS BOARD forum
FICHT OR ETEC ...book pretty much says the same
If the Check Engine warning light illuminates, first check the battery condition as detailed under Batteries in the General Information and Maintenance section. If the battery is good, the EMM may have detected a fault within the electronic engine control system (and stored a diagnostic trouble code). If the EMM detects a fuel injection or electronic engine control fault, it will store a Service Code, sound the horn for 10 seconds and illuminate the gauge LED for a minimum of 30 seconds. The light will go out if the fault does not remain present, otherwise the LED will remain illuminated until the fault goes away or the key is turned off (whichever comes first). If the fault is still present the next time the engine is started, the LED will illuminate_once again to alert the operator that problem is still present.
If the Check Engine warning light illuminates, first check the battery condition as detailed under Batteries in the General Information and Maintenance section. If the battery Is good, the EMM may have detected a fault within the electronic engine control system (and stored a diagnostic trouble code). For more information, please refer to Reading Codes in the Self-Diagnostic System portion of the E-Tec Fuel Injection section.
T.bass
Thank you, I thought it might could have been a battery issue but was not sure it would cause the check engine light to come on. I was also going to change the fuel filter but can not find it on the boat or motor.
Crosbyman
without EV diag ver 5.9 ($100) you are working blind swapping parts is $$$$ ....
POST YOUR ENGINE mdl #
presumably a FICHT and you can read the codes on the tach display (see manual for instructions)
see this link and download the 2002-2006 FICHT/ETEC book (covers both)
