dingbat
- Joined
- Nov 20, 2001
- 16,889
Unless Garmin changed the design, that may not a valid reading.The voltage indicator on my Garmin
Had an issue a while back when my Garmin was reading 1 volt lower than my voltmeter. Turned out the unit was reading system (internal) voltage, not actual battery voltage. Confirmed with Garmin tech support.
Suggest you check the voltage on the power connector at the back of the Garmin with a voltmeter to confirm readings.
Could very well be burning up regulators in a over voltage situation.
