Can you replace all 3 trim and tilt cylinder seals without taking trim and tilt assy off motor,
A alexandery Cadet Joined Oct 12, 2008 Messages 17 Oct 31, 2023 #1 Can you replace all 3 trim and tilt cylinder seals without taking trim and tilt assy off motor,
B boscoe99 Commander Joined Aug 22, 2013 Messages 2,193 Nov 1, 2023 #2 Probably. But why would you want to?
A alexandery Cadet Joined Oct 12, 2008 Messages 17 Nov 2, 2023 #3 I already repaired the outer trim seals dont know if tilt rod and piston will have enough room to be removed in place will it hit the motor ?
B boscoe99 Commander Joined Aug 22, 2013 Messages 2,193 Nov 5, 2023 #4 The entire assembly can be removed from between the clamp brackets.
A alexandery Cadet Joined Oct 12, 2008 Messages 17 Nov 8, 2023 #5 Thanks for reply have ordered the seals will take my time hopefully no problems
