2005 50 hp back fires
Crazy boater
When it back fires it has a puff of smoke from around the flywheel would that be a bad flywheel seal or something else
thanks
Faztbullet
That is a lean condition and cause a internal crankcase pop. Cause by carb issues or seal. These are know to come loose..
Crazy boater
Thanks for the reply
Since it's up by the flywheel do you think I should pull the flywheel to check that seal
