I'm having trouble narrowing down a problem. I have replaced the starter relay and I still can't get 12 volts past the relay. I am getting good voltage up to the relay but when I read the voltage during starting at the starter I'm only get around 6 volts, and a small ground wire from the starter relay holder to the head has melted. I've spliced the ground wire and it melted again. The wiring in the boat is all new from the batteries to the engine. Could this be an instance of receiving a bad relay when I got the new one because its doing the same thing as the original relay. Please help, I need to go fishing!
