Z200, cant find the blue? remote oil tank plug on the engine harness, also i want to mount the oil tank under console or is it better closer to the engine? Thanks for any info.
its there, it may have changed colors for 06. the tank doesnt care as long as its accesable for maint and dry and close enough for the hose and harness to reach.<br /> best I remember the connector is low on the stbd side near the shift slide.
Thanks... found it in a inclosed box. also do i need to purge the oil pump, phillips head srew , then open oil pump lever wide open for first ten mins at idle? Thanks<br /><br /><br />Ol MAKO
