2006 Mercury 9.9 4-stroke kicker won't start with fuel line attached
badcrc
My nephew has a 2005 Starcraft Fish Master with a Mercury 175 2 stroke main motor and a 2006 Mercury 9.9 4 stroke kicker. It's been sitting several years and he's trying to get it running. He had had the 9.9 running but it ran poorly and was leaking fuel out the top of the carb, so we rebuilt the carb and cleaned the jets and everything, replaced the fuel filter, plugs, etc. So after all that it wouldn't start. Then he disconnected the fuel line and it starts and runs great until it burns all the fuel in the carb. The fuel line for the 9.9 is T'd off of a line shared by the 175. The 9.9 has electric start and remote throttle/choke. Looks like a solenoid and servo motor that controls everything.
I thought it was fuel pump related so we took that apart and it looks ok, but not great so we ordered a fuel pump diaphragm kit and haven't installed it yet. But when we plug the inlet and blow into the outlet, it has pressure. That seems to indicate the diaphragms are good, correct? I'm also wondering if the diaphragms are bad how that would stop it from starting with the fuel line attached...wouldn't the carb float needle valve stop excess fuel? The fuel pump has four fuel connections, 2 near the top and 2 near the bottom.
There is also a plunger/rod assembly deal on the corner of the carb, with a check valve inside the carb that sits on top of the plunger. That plunger looks like it's in good shape but I'm not sure what that thing is for. I have a feeling this fuel pump rebuild isn't going to fix this problem, so if anyone has any pointers that would help. I've never seen an issue like this before.
badcrc
Do not tee into a fuel line for another motor !
That's how it was setup originally...they've had the boat since it was new, but I believe in 2006 when my brother bought the kicker, Cabela's boat shop set it up like that. Never had an issue with that part, it always worked fine, but it seems weird to me. There's separate primer bulbs for each line, but only one line going to the fuel tank. Then there's oil tanks that only go to the 175 2 stroke.
cyclops222
Remember If the carburetor engine runs dry. The other engine will only suck air from it. As the float needle is hanging down.
badcrc
Thanks for the replies....we suspected something might be caused by the fuel line setup but we kept coming back to the fact it was that way for 15 years and didn't have a problem. Like I said in my other reply, I'm fairly certain my brother had the boat at Cabela's boat shop where he bought the kicker and they set the whole thing up....steering, fuel, etc. Maybe something changed after it sat for that long. I'll tell my nephew and see if we can change the setup and see if that helps.
