2007 15 hp 2 stroke carburetor
pamacm
How do you adjust the idle; motor does not have conventional screw adjustment.
tblshur
pamacm did this problem just start ? is this motor new to you ? have you done anything to fix the problem?
iggyw1
Ensign
May as well post the model number because someone will need it to answer your questions. For adjusting the idle speed, some motors have a idle knob for this purpose at the end of the throttle handle, unless you are asking how to adjust the fuel / air ratio.
pamacm
Yes, the fuel/air ratio. the idle speed adjustment at end of throttle handle does not work. Model # J15RLSU
tblshur
check post #2 i dont think these carbs have adjustment they have fixed jets
tblshur
normanly i would think rebuild /or good cleaning on carbs but you need to give a bit of info
Vic.S
The idle speed adjustment does take a bit of figuring out. It is a stop or limiter to the movement of the throttle rather than a direct speed adjustment and it does take quite a bit of twiddling to make much difference.
If you want to reduce the speed twiddle the knob in the appropriate direction and then you will find you can close the throttle a bit further.
If you want to speed it up open the throttle a bit first, twiddle the knob then you will find the throttle wont close quite so far.
As said there is no mixture adjustment
Don't these motors have a full throttle stop screw and an idle stop screw on the motor ?----Look for them on the arm, starboard side of motor block.
