2007 50hp Honda Starts, Runs, Cuts out
retsbnmgr
The subject engine will start and idle for several minutes, however then cuts out and will not start again for several minutes. The same process is then repeated. The primer bulb is practically collasped and does not seem to get full. Would appreciate any suggestions or help. Thank you. We're new to this forum.
hondon
Re: 2007 50hp Honda Starts, Runs, Cuts out
Your fuel delivery is not venting or you have a picnched fuel line somewhere.Are you opening the fuel tank vent if it is a portable?
retsbnmgr
Thank you. It's a built in system and I'm sure you're correct, however can't find the pinch or location of the cause for the fuel starvation.
gss036
Make sure you primer bulb is working right. Then chek the pick up in the tank, mabe something is sucking up againt it and cutting off fuel flow.
kandil
Is it under warranty? if yes you should take to the dealer.good luck
